Remote Access Firewall Issue
mhertwig
Sep 2021
London
Good Morning.
Our local IT group has been trying to get some of my PLCs online with the plant network so I can remotely access. They are stringent on cyber security, etc, so they have to deal with some firewall issues. Right now they have got us to the point were I can access the machines from an external VPN connection, but not a local plant connection.
This is a L30ER v20.014.
He has asked me this:
"it is concluded that something is one the PLC that is blocking replies, there should be something on that machine maybe like IP filtering, IP route filtering or something else, can you make sure that none of this configured ?"
Any thoughts here? Could the PLC be blocking network access?
When IT refers to "that machine," is IT referring to the PLC?
And are they actually asking if the PLC has IP filtering?
Ask them to show you a log, from the same LAN the PLC is on, of the packet they conclude has been blocked or filtered. It should have the MAC address of the PLC in it; if it only has the IP address of the PLC, then it is not from the same LAN that the PLC is on.
As others alluded to, direct firewall connection is not recommended. Either use a VPN or a Jump Server in addition to firewall. You can even go as far as adding a physical kill switch to prevent outside connection.
No, PLC doesn't "block" ICMP pings and I'm not even sure that's possible on AB network card.
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
615
Hi everyone, I have a project involved with Toyota whereby the customer would like to be able to control devices within a booth using a portable...
240
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,244
Hello everyone, nowadays i am working on a project for remote access to our machines. We are using a remote access module, but i want to make my...
398
Hello PLC Friends, I'm starting my final year project with a given rig and I'm thinking about incorporating a remote access feature where I can...
372
