Remote access to Controllogix
lostpatrol1
Aug 2002
67
Does anyone know any other way to remotely access controllogix PLC programs (to edit or view online) other than the dial-up Etherneet modem?
The dial-up e-net modem is way too slow.
TIA!
I have used a VPN on a DSL connection to an EN2T card on several occasions. Works well once you have everything configured.
EDIT: Arg, you beat me LJBMatt
If the remote place has a VPN server you can log in through that. That basically makes it the same as if you were plugged into their local network. Then you can find it through RSLinx as usual.
You can also try remotely controlling a PC that is physically plugged in to the PLC's network with something like Webex. The local PC has to have the program and RSLogix 5000 on it, though.
VPN will probably be the best way.
Hi, we have a machine with a ControlLogix rack and 2 EN2T network cards in that rack. One is for the normal Ethernet/IP subnet (192.168.11.xxx)...
2,897
Hi all. Got a job I have been asked to look at. But I'm no sure whats the best way to tackle it... I have several tags i need to display & be...
2,802
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
615
Hi everyone, I have a project involved with Toyota whereby the customer would like to be able to control devices within a booth using a portable...
240
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,242
