Remote access to the processor and VFD
Snap25
Dec 2014
Michigan
237
I was wondering if anyone had any feedback or reviews of any cellular remote access devices?
I have a company who wants me to set up remote access to one of you machines without using their network (they are having problems with it)..
I was leaning toward netbiter's Easy connect EC350 or Digi Connect WAN IA Routing Gateway (DC-WAN-B205). Would you use a sim card or a Verizon hotspot USB drive? Could I still run an antenna for better signal using the USB drive plugged into the device?
Also, we have a powerflex 4 VFD in the panel. They want me to be able to remote access the parameter settings and readouts. I don't think I would be able to with that powerflex? Is there one out there someone could recommend to me?
Thank you
Check out Spectrum Control's WebPort VPN. You can get the cell version. I'm not familiar with Powerflex 4 but assuming it got local network access to the VFD you can then run Drivedirect (or whatever it's called these days) through the VPN.
Harry,
Thanks, I will check it out. I guess I really don't need the cellular service. I just need it set up where I do not have to go through the companys IT department.
I have the remote access figured out. I'm going to go with a **** VPN router and throw an CDMA modem with a data plan as an option.
What is the best way to communicate remotely to the VFD as seperate entity from the PLC. Should I upgrade the powerflex 4 to something new like the 525?
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
599
Hi everyone, I have a project involved with Toyota whereby the customer would like to be able to control devices within a booth using a portable...
238
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,236
Hello everyone, nowadays i am working on a project for remote access to our machines. We are using a remote access module, but i want to make my...
396
Hello PLC Friends, I'm starting my final year project with a given rig and I'm thinking about incorporating a remote access feature where I can...
369
