Remote control for PLC
Exceptions to every rule. Most raw material handling plants have miles of conveyors that start all the time unattended. Usually with blast horns as a warning of impending movement.
But the operator is not climbing in the machine at the time. The horn is a warning to stand clear as movement is imminent
An operator most certainly could be climbing into the "machine". Redoing belt splices, adjusting tracking switches, oiling gearboxes, etc. All out of sight from the start control location. The point is there are many instances of remote control out of line of sight. That's what local disconnects and proper LOTO are for, as it's impractical to guard or cage such systems.
Install Anydesk on a smartphone and the PC used for SCADA. Don't fall off the ladder using your phone to try to control the PC. This would mean the PC needs internet access, which is a whole 'nuther can of safety worms.
1. Have a test/commissoning mode that is selected by a key switch.
2. Create a very simple web-server HMI of your choice only for testing/commisioning. When test/commissioning mode is selected, then use the web-server HMI to select the device to test, and the type of action ON/OFF, UP/OFF, DOWN/OFF etc. If the webserver is reachable by wi-fi, then the person doing the testing can use his smartphone.
3. Arrange a 'dead-man' switch connected to a safety relay. When the dead-man switch is half-pressed, the chosen action is activated. When the dead-man switch is fully-pressed or released, the action is stopped via the safety relay. The dead-man switch can be at the end of a long cable so that you can bring it with you everywhere around the machine.
N.B. You need to consider the speed of actuators. If the actuators are so fast that it is not realistically possible to remove the limbs that may be caught by the movement, then it is not possible, or you need to provide a system for 'safe low speed'.
N.B N.B. in case this is not clear from the above. All of this should be covered by a risk assessment.
My boss has come up with the idea of renting machines and charging on a per use / per hour basis, so I'm looking into it - just getting my feet...
3,981
I need to implement the following application - it needs to be remotely connected via a Internet-11 PLCs*(with Ethernet on board) with one central...
1,721
Hello friends I have a water level control, with ML1400 and PanelView1000 through Ethernet. I need to monitor and control this simple machine...
2,214
Hi All, I am working on a project using Woodward Easygen 3200 and a PLC for remote control. I have figured out how to run the generator remotely...
2,485
I have a plc that runs a countdown clock i made. I would like to start and stop this plc via a remote control device. I would like to get a...
3,065
