Replacing a bad SM-332??
LarsonJL7
Mar 2012
Oregon
Hi, we have a bad output on a SM-332 analog output module that controls a modulator on our oven. Since this plant uses primarily AB PLC's I have very little knowledge on Siemens.
My question is, can I power down the PLC and take my spare SM332 card and just swap it out with the new card and be off and running again or will I have to download the program to the card or is there another procedure??
I will have about an hour next week when I can power down the PLC so I want to be as prepared as possible. I looked through the SM 332 manual and searched the web and haven't found an answer yet. I am sure this is common knowledge for the Siemens gurus here.
Thanks for the help!​
Turn off the power and swap (push the plastic "buttons" the top and bottom to remove the connector, the wire can stay on the connector
Also there is one screw at the bottom of the module and the module flips up from bottom to top
A two second job
Your good to go
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
112
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
594
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,211
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,476
I have a processer that stopped functioning L32E. The only spare available is an Compact L33ER. Are these processers compatible? The IO is...
2,239
