Replacing an iQ-R04 CPU with an iQ-R04EN CPU
cottagewood
Oct 2005
Kent
179
Module Configuration in GXworks3,
I have a configuration with an R04 CPU and Slot 0 is empty
Does anyone know how to replace the R04 CPU with an R04EN CPU?.
You would think this would be straight forward.
Under the menu Project/Change Module Type you can select an R04EN but you get an error telling you there is no RJ71EN71 to the right of the CPU.
So I put an _RJ71EN71 in Slot 0 but then get an error telling me that the CPU to used in conjunction with it is not mounted.
http://www.plctalk.net/qanda/images/smilies/banghead.gif
You need to select the module for slot 0 from "CPU Extension" in the element selection window not from "Network Module"
Yes, it seems when you try to change from R04CPU to a different type, there is a limited choice of CPUs that can be selected, R04EN not included. It seems you need to create a new project with the R04EN, reassign the IO and copy+paste the logic. Sorry for not being able to provide more help.
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
118
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
612
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,223
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,507
I have a processer that stopped functioning L32E. The only spare available is an Compact L33ER. Are these processers compatible? The IO is...
2,263
