Resetting a NET-ENI module
arrowpilot
Dec 2003
PA
34
Hi all,
Playing around with a Net-Eni connected to a ML1500. (Been a while since I've done this.) So anyway, got things running with the default IP of the ENI and was able to get online to the CPU.
Fault light keeps flashing on the ENI and I assumed that was because I was using default settings??
Anyway, earlier when I was messing with the Com Redirector (no serial cable at home!) and the NET-ENI config utility I could do no damage but was unable to change the IP in the ENI. Eventually I got brave and tried to do a file save to the ENI from the utility. This hosed things up and I can no longer ping the unit or get to it from the utility.
BOOTP still shows the ENI and it's default MAC address. But it's got me locked out.
Any tricks to getting back in or resetting this thing to default??
Thoughts are certainly appreciated,
Mike
msmassey said:
I think you are going to need the cable
The more I've been thinking about it...thats what makes sense.
I should be enjoying the weekend rather than tinkering anyway! I'll have the AB cable on Monday and see what happens.
Thx for the reply.
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
243
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
307
How is it going y'all? So We have had a pesky problem with an EH 300 flow meter. We are using EIP to reset the totalizer, and for some reason the...
802
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU Hello. This is for the Mitsubishi experts, and thanks in advance...
1,071
Hi all, is there an easy way to reset a user defined shift register to 0? i have a data type containing 8 bools for an array of 10 and would like...
3,202
