Can I reset an individual Electronic blown fuse on a Discrete Output Module (1756-OB16D 16 pt 30v Output) channel without affecting the other channels?
Golly are there electronic fuses? What will they think of next??
Are you referring to a circuit breaker or just a fuse?
Is the fuse on the power supply to the card? If so I would not replace it hot I would deenergize (same idea as with hot swapping cards but I am chicken).
Why did fuse blow?
If fuse protects the output I think you could replace it without shutting down.
