WallyPrestone Member W Join Date Aug 2005 Location Torrance, CA Posts 121 Apr 20, 2007 #1 Please help to find the parts number and vendor to purchase the RJ45 Crimping tool . Thank You
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Apr 20, 2007 #2 http://www.cablesnmor.com/rj45-crimping-tool.html http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1779585 http://www.etool.ca/eTool/RENDER/1/56/500/11009.html http://www.cdwg.com/shop/products/default.aspx?EDC=784734 http://www.l-com.com/productfamily.aspx?id=1189
rdrast Lifetime Supporting Member Join Date Apr 2003 Location South Carolina Lowcountry Posts 5,544 Apr 20, 2007 #3 Advice, if this is to be used professionally... Go with something like the third or fifth links above. (or an AMP tool). Basically, any ratcheting crimper with interchangable dies are much much better than the cheap tools.
jroachell Member J Join Date Apr 2007 Location Sacramento Posts 10 Apr 20, 2007 #4 I like the tool in the 3rd link. Although I never change out the die, it is a professional grade tool and the crimps it makes are consistently better.
WallyPrestone Member OP W Join Date Aug 2005 Location Torrance, CA Posts 121 Apr 20, 2007 #5 Thank You Mickey You Are Great !!!!!
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Apr 20, 2007 #6 WallyPrestone said: Thank You Mickey You Are Great !!!!! Click to expand... I know and your welcome.
OZEE Member O Join Date Mar 2006 Location Kansas Posts 1,696 Apr 20, 2007 #7 Isn't Google a wonderful tool!! Last edited: Apr 20, 2007
DesertDog Member Join Date May 2003 Location North of Los Angeles Posts 350 Apr 20, 2007 #8 I have had no problems with the one in the fourth link. Mine works for both RJ45 and RJ11 without any kind of changeover.
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,608 Apr 20, 2007 #9 This is the one that I have. Using it will make you awesome.
