Rockwell FactoryTalk data logger files?
patjdixon
Nov 2018
Lago Vista, TX
63
I have seen posts about the Rockwell FactoryTalk ME DataStore Plus ActiveX control to save historical data to a CSV, but frankly the caveats seem very daunting. People have expressed concerns about handshaking, error handling, having to save data to PLC UDT, and performance impact on the HMI. I have logic running on a distillation column and do not want anything that puts the logic or HMI at risk.
I have the easy and safe to use Data Logger working that can show historical data on a trend, but it isn't very helpful for data analysis unless I can get the data into a spreadsheet. I think the data is stored in proprietary "MDF" and "LDF" files. It would be great if there was a conversion tool to CSV.
It looks like I have 3 options:
- Accept the headache and risk of DataStore Plus
- Hope I can find a way to convert "MDF" or "LDF" into a data file that I can import to a spreadsheet
- Give up and eyeball the trend the best I can
Any advice?
is MDF Measurement Data Format (vector.com)?
is LDF LIN Description File?
Can you post examples here (put them in a .zip archive)? It might easy to convert them to CSV or even to eXcel format.
update: see here; so a solution exists; converting data read into a Python scrit to eXcel is trivial.
Hi All, I'm using Factory Talk View Site Edition running on a PC, and have set up saving Historical Data files using MS SQL Server as supplied...
14,339
I have been trialing a Proxmox based development server for my group but have had no end of troubles with the several instances of VM I have...
250
Has anyone gotten FT working on Proxmox based VMs? I've been working on trialing Proxmox in place of ESXI for development servers and FactoryTalk...
68
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
548
Is it possible to download and use the Transfer Utility of the Rockwell FactoryTalk View ME ? only the Utility ? without any special requirements...
5,312
