Roll your own MAC address?
danw
Oct 2004
midwest, USA
3,428
This line was buried in the spec for a cheap Chinese serial server (RS-232/485 to Ethernet):
"The global only MAC address bought from IEEE, the user can define MAC address (please state when you make order)."
I thought ranges of MAC addresses were doled out to manufacturers by some entity, carefully managed so that no two were identical.
Now it's a roll your own MAC address?
Is this common in the cyberworld or is it just another fulfillment of my father's saying, "Son, there's nothing somebody can't make cheaper. Remember, you get what you pay for."
Dan
http://en.wikipedia.org/wiki/MAC_address
If you look at the actual MAC address specification, by changing bit 2 of the most significant byte, a MAC can be set as either global (0), where the org makes sure it is unique, or local (1), where you can do whatever you want.
Could be they have two versions, one with a fixed MAC and one with a variable one. I've never seen an application where changable MAC addresses was required or useful, except with wireless clients.
This might not be as uncommon as you would think. Rockwell were recently shipping Powerflex 525's with duplicate MAC addresses. I also thought that this was not supposed to be possible.
I just bought two ip-camera's and when i'm looking up their info they have both very weird originating factories... based on their mac adresses... well it's running out like ipv4 i guess
Back in the dark ages when Ethernet was not as common as today I remember when we changed an expensive Siemens Communication card in a PC to a standard Ethernet Card we had to change the MAC adress of the new ethernet card in the PC since the communication card in the in the S5 PLC was set to only communicate with a certain MAC. Do not remember how.
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
807
Say I take some MODBUS registers and pull into my Logix plc DINT array (sequential). Now, I get a little fancy… using FactoryTalk View SE 13.00...
18
3,208
I am going to be interfacing a Fanuc robot to a Toshiba molding machine. Is it acceptable or good practice to use Ethernet between between the...
6,618
I have an application where I need to control the temperature of a product in a vessel. The basic setup of the system is a container for the...
3,489
Hello. I was wondering if anyone had had a need to 'roll their own' recipes? My customer has a SLC 5/05 connected to a PV+1000 all on ethernet and...
2,025
