rotary positioning without Encoder....
How fast is the shaft turning in Revs Per Minute or Mins Per Rev.
Does it have a home position
If it is slow turning and has a home position I guess you could use time to get to the position required
shaft is fast turning, it is around 150-180 rev./mins. I don't think so that i can get it with time. Yes shaft has its home position.
Take a lot of money when You finish Your job. Positioning without ANY position detector is worth a Nobel Price :)
Encoder
If your using a plc you could use a proxy...switch and read a pick up on the shaft or motor and use a count rung if intersted in this style of position reading these guys on this site can explain it far better than i could ..i know it works well at low rpms we use this style on a polisher where i work to read the polishing stone position/height ..mer
Hi all
Is it possible that a shaft positioning can be done without encoder or a shaft positioning cam???
Many years ago in the sawmill industry this type of thing was done on the log carriage.
Here is how it worked. The "sawywer" would signal the "setter" (human riding the carriage with the log) with hand signals. The environment was too noisy for any other form of communication. The "setter" would rotate a shaft with however many clicks of his ratchet handle the communication request indicated. The shaft rotation would advance the log for a thicker or thinner board to be sawed from the log.
It strikes me as ridiculous to ask for positioning without any position sensors. Kind of like asking for an output with no input. But then, I'm not exactly an expert in that field either.
I have done this many times, positioning of shaft without any sensor but only for slow speed normally 50rpm can be done easily . but the problem in this case is that the machine is high speed and I am unable to control it. I want positioning with the turn of shaft.
Thankx milldrone
but the problem still exist coz of speed.
Anyone can share their experiences on performing precision indexing with PowerFlex using solely an absolute rotary encoder attached to the load...
2,976
This is not a PLC question, but maybe one of you have seen a product like I am looking for. I have a portable pneumatic misting system that is...
587
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
484
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,485
I'm looking for electric rotary actuator with field bus.
1,179
