Rotary stepper switch replacement
shawn_75
Apr 2010
KY
432
I am looking at replacing an old rotary stepper switch. This is an application where I could use a PLC, but other than the sequencing of the switch, there is no other need for a PLC. I cannot find a modern, low tech, replacement for a rotary stepper switch. I'd like to have 12 sequenced positions of the stepper. Anything out there? I'm about to build my own hardware, if need be.
depending on the voltage and the current you can use a simple rotary switch (having 12 positions, from RS farnell or bigger from schneider etc.
This is not a PLC question, but maybe one of you have seen a product like I am looking for. I have a portable pneumatic misting system that is...
595
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
488
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,488
I'm looking for electric rotary actuator with field bus.
1,183
Hi, everyone: I tried to understand the basic knowledge of CIP motion control axis configuration. we have one rotary axis (kinetix350) in our...
1,135
