RSL5000 PID Gains Question
ndzied1
Aug 2002
Chicago, Illinois
2,857
Do the gains in the RSL5000 PID instruction work on values in percent or in engineering units?
Trying to help a colleague in the field tune a loop for controlling water flow with a motorized ball valve. Feedback seems good and is close to the valve but I have never used the RSL PID and am trying to get a feeling for the tuning.
Norm,
I haven't use the PID in RSL 5K but I have a question about your application. You say you are using a Motorized Ball Valve to control flow. Its it a V-Ball Valve or just a standard ball? If it is a standard Ball you may play hell getting the loop to settle down. Since a standard Ball Valve is not linear flow control can be very difficult. A lot will depend on how fine you want the flow control and how often the look has to make adjustments.
I have had this issue in the past so I thought I would share. Hope it helps.
I don't see anything in the reference manual, does anyone know if the Control Variable tag can be changed in the PID instruction so that I could...
2,179
Just curious, trying to make set up of 20 PID tags identical. What if on first scan I COPY MyPIDtag01 to MyPIDtag02 Length 1 COPY MyPIDtag01 to...
2,927
Hi fellas, I've just learned of an upcoming project that I'm going to be asked to do the programming on. Details are very sketchy at this point...
19
6,155
I am using version V17.01.00 (CPR 9 SR 1) I have a fairly large machine with multiple PIO nodes on an ethernet network. I am getting a flashing...
1,427
Hello, My coworker and I are commissioning a new panel. We have a 1732-AENTR series C remote IO thats Rev 6.1. The project file from a previous...
1,622
