RSLinx driver configuration
rebotchw
Mar 2007
Charlotte
I am trying to configure the RSLinx drivers. After going through the communicatins >> configure drivers etc, I only see the workstation and not the PLC, we are using ethernet as the device type. Any help will be appreciated.
Two cents contribution to the questions: be sure your PC doesn't have the same IP address of the PLC and be sure if you connect directly from the PC to the PLC to use a "cross" Ethernet cable or if you don't have a cross cable, use a switch/hub between the PC and the PLC.
Thanks for all the reply. We see an object after the configuration with the following
Device Type: RSLinx
Online Name: RSLinx Server
Status: Self Testing
I will check the connection to the PLC
Is there any way to script driver configuration instead of using the rslinx gui? It would be nice to just have scripts i can run for whatever...
1,612
I have a number of clients who have large Rockwell PLC networks with deep hierarchies. Since RSLinx cannot auto-browse the Ethernet networks on...
3,015
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling...
615
How does RSLinx Classic EtherNet/IP Driver "Windows Default" adapter relate to the all of the available Windows adapters? Is there a way to...
2,511
I installed RSLinx Classic OEM 4.21 and tried to configure a Ethernet/IP driver on it, but in the RSWho window I cannot see the workstation or the...
1,855
