RSLogix 1756-L72S communicating serial to thin client
dmbartender
Jul 2008
Germany
40
Hello guys. I have until now always communicated with other machines via either relays or ethernet. Now I must provide a thin client with one INT over a serial interface from my control logix rack.
The L7x no longer carries a serial interface. Is there a serial card I can put in the rack for this simple purpose? I think I have found one from Prosoft and one from Molex, but if anyone has any experience in this kind of application, I would like to hear your opinion.
Thanks!
What protocols does the thin client support ?
Are you looking for lowest cost, best performance, or best ease-of-use ?
My first instinct would be to use an EtherNet/IP to Modbus RTU serial converter. The Digit One IAP and HMS Fieldbus Communicator, as well as Prosoft's standalone and rack mounted modules are the ones I am most familiar with.
I am not sure about the thin client -- I don't have any information about it. There is a template project however where this was done already, with an AWT command in RSLogix. This and other commands are however only valid for processors with serial ports on them, apparently.
I am thinking of putting a second PLC, L61 in the rack just for this communication. Overkill, and expensive, I know.
Unfortunately RA never built a module that directly replaced the Channel 0 serial port with a port that supported MSG instructions and ASCII instructions.
Since the module is probably using ASCII, the most straightforward thing would be to re-create that functionality using a Prosoft MVI56-GSC (Generic Serial) module.
If you happen to have POINT I/O nearby, the 1734-232ASC module is also an inexpensive and simple way to transmit and receive delimited ASCII strings from a ControlLogix.
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
628
When I installed my RS Logix to another computer version 18 and I went online and tried to look at the properties of the 1756-IF6CS it would no...
1,152
Hi All, This topic it is really interesting indeed. Hi have a doubt that is inside this kind of questions: RSLogix 5k V28, 1756-L73CPU value...
2,591
Hi all, I have an issue with 1756-L62S (revision 20.13) safety lock. We can't figure out who put safety lock on our project. Before I try...
1,032
2,437
