RSlogix 500 File open failed
Greetings...
I know this is an old thread, but perhaps this will help someone. If the folder that the .rss is in (whether directly or nested) has a special character in the folder name (such as ā™¦, ā€¢, or similar), this error will be generated. Move the file to your desktop and try to open. If it opens, then either the folder name structure is corrupted or a special character has been added to a folder name in the tree where it resides. If it does not open, then the file itself is possibly corrupt.
Cheers
Steve
I know this is an old thread but I need to resurrect it! I have the same issue, but in a different way. Same virtual machine we remote into, I can open the file, my co worker can't. Same folder, same everything. Just a different login name but we but 100% for certain have the same user rights on the account.
Is there an error message you can share?
Are you both logged in at the same time when this happens?
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
782
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,204
Hello All, I created the shortcut while setting up comms in FT View to a Logix 500 processor, then a offline tag file to the processor .RSS file...
1,724
I'm troubleshooting this machine in the field right now. The discrete outputs of this Micrologix 1500 are wired to discrete inputs of a Siemens...
1,533
Hi Guys! Does anyone know which version of RSLogix 500 i can insert ASCII DataFile? I'm using 10.0 version and i not found this DataFile, but...
1,455
