RsLogix 5000 Time/Date
Ok, this is my very 1st post. I've been a viewer since 2005.
-I downloaded the DOW "add on" from post #10 to my L61 ver19 processor and it shows the day of week fine but how do I get it to update itself to the next day.
Help!!
Rocan,
It will update itself automatically.
Check out this file and see if it makes more sense.
There are other ways to do it but this should show you how it all works.
Mark
I am using the GSV to find year/time etc. However, my PLC doesnt show the correct data, year : 1998...date is wrong and so on.
How do I fix this?
Then you haven't set the PLCs clock.
Go to the controller properties - date/time tab and set the PLC clock as you want it, or click the button to set it to the same date/time as your programming PC. See the pic....
CCW_RTC_READ_1, how get separately hours, minutes and second?
Hello,
i have one problem, i need separately hours, minutes and secons in PLC 850 2080-LC50-48QWB,
i used block RCT_READ and i see minutes and so on in Local variables:
RTC_READ_1.RTCData.Minutes i see how minutes changing and i don´t to next use this variable
>>>in seven rung is block MOVE and input value= RTC_READ_1.RTCData.Minutes (viz. images)
and after compiling announce warning messages:unknow field structure.
please help
thank you
lacek
Czech Republic
DayOfWeek_LD status
I have been reviewing the information from post #10, and implemented it into my ladder logic. When I run the program, the value I see is always 0 (zero). Is there something I need to enable to see the day of week showing 0-6?
Thanks for your help,
Chad
Chad
are you JSR'ing the subroutine that the AOI resides in ?
Hello Gentlemen, I am having this weird issue. I can see the controller on Rslinx via ethernet. when I open the RSlogx 5k, open RSWho, I still...
1,988
I want to update the firmware 15 to 20 on a ControlLogix 5561 Processor, Cat series 1756 L61 B. Is this possible? There are other components...
22
7,561
I appear to have an issue with RSLogix 5000 software. It appears that the publishers certificate is out of date. I am unable to open the...
1,569
Hi guys, I want to update Rslogix 5000 v20 to v30.kindly support and guide me to update version 30. Kind regards. Ju
3,103
Hi, I was monitoring a compactlogix online today and was watching a timer value and rslogix 5000 only appears to update the tag value displayed...
2,320
