rslogix 5000 use of compare instruction to add-on-instrunction
md.abdullah
Sep 2011
motihari
168
can i include some compare instructions or any instruction to the my add on instruction or in the udt in rslogix5000.i know this may be possibly not happen but
any suggest..to use the compare instructions in the add-on-instrunction
UDT's are templates for DATA.
AOI's are templates for LOGIC.
You can include some instance data in an AOI, but you cannot include any logic, instructions, programming, limiting, or anything but data in a UDT template.
AOI's can have just about anything code wise that you can write as a non-AOI, with the exception of special instructions like MSG instructions, or motion instructions. Basically, anything that MUST be controller scoped to function cannot be in a AOI.
The manuals are good.
So is the sample code.
Hello, Currently on my laptop have rslogix 5000 v16_20 and I'm not able to see the compare sheet of parameter for vfd powerflex 40p over comm e...
1,289
Hey there, I'm trying to compare the amount of counts in any 5 minute period. What I'm doing so far is when each count is made true, a binary...
2,673
when I use rslogix 5000 compare tool for two particular ACD files, I get an error "an entry with the same key already exists." It happens onlly...
14,082
Does anyone use the Compare Utility from RSLogix? I would like to use it in a batch mode if possible. Can it be run from the command line with...
5,479
What does "mv" mean on the side of the comparison windows in RSLogix 5000?
2,669
