RSLOGIX 5000 V19 Install Error :1603
seymour_andy
Feb 2010
CHESHIRE
I'm Trying to install RSLOGIX 5000 V19.01, soon after install begins i get the following errors in log file.
MSI (s) (9C:18) [12:30:53:539]: Deferring clean up of packages/files, if any exist
MSI (s) (9C:18) [12:30:53:540]: MainEngineThread is returning 1603
MSI (s) (9C:F0) [12:30:53:561]: RESTART MANAGER: Previously shut down applications have been restarted.
MSI (s) (9C:F0) [12:30:53:562]: RESTART MANAGER: Session closed.
MSI (s) (9C:F0) [12:30:53:562]: No System Restore sequence number for this installation.
=== Logging stopped: 06/03/2012 12:30:53 ===
MSI (s) (9C:F0) [12:30:53:563]: User policy value 'DisableRollback' is 0
MSI (s) (9C:F0) [12:30:53:563]: Machine policy value 'DisableRollback' is 0
MSI (s) (9C:F0) [12:30:53:563]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (9C:F0) [12:30:53:563]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (9C:F0) [12:30:53:563]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (9C:F0) [12:30:53:563]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (9C:F0) [12:30:53:564]: Restoring environment variables
MSI (s) (9C:F0) [12:30:53:564]: Destroying RemoteAPI object.
MSI (s) (9C:A0) [12:30:53:564]: Custom Action Manager thread ending.
MSI (c) (10:24) [12:30:53:566]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (10:24) [12:30:53:567]: MainEngineThread is returning 1603
MSI (c) (10:14) [12:30:53:571]: RESTART MANAGER: Previously shut down applications have been restarted.
MSI (c) (10:14) [12:30:53:571]: RESTART MANAGER: Session closed.
=== Verbose logging stopped: 06/03/2012 12:30:53 ===
Setup Plugin: *** System Update logging end ****************************************
Setup Plugin: End RSLogix 5000 OS update: update failed: 1603
Can anyone help ?
Andy
__
you receive an "error 1603: A fatal error occurred during installation" error message when you try to install a windows installer package:
You may receive this error message if any one of the following conditions is true:
The folder that you are trying to install the windows installer package to is encrypted.
  • the folder that you are trying to install the windows installer package to is encrypted.
  • the drive that contains the folder that you are trying to install the windows installer package to is accessed as a substitute drive.
  • the system account does not have full control permissions on the folder that you are trying to install the windows installer package to. You notice the error message because the windows installer service uses the system account to install software.
Can anyone help ?
Andy
did you find any solution ?? i have same Problem.
The Knowledgebase answers are still the best guide to solving this problem.
What OS are you trying to install the software on ? Is the System account configured with administrative rights to install this software ?
Ive recently been having trouble with the stability of my connection when online with a plc, The software intermittently freezes (cogwheel...
2,073
V19 does not run on my Windows 10 laptop, I tried everything - run as administrator - compatibility Vista, 7, XP - reinstall .net framework Has...
5,293
I have a project I am re-doing and would like to clean up the I/O tree by removing some un-used modules. I know in order to delete them I need to...
4,324
Hi guys. Sorry for my english. :rolleyes: I have some problem with RSLogix 5000. I worked with version 20 with any problems. I'm working on...
4,775
Hello. I was working on commissioning some control logix programs when I somehow lost the ability to force I/O's form the controller tag screen...
3,669
