RSLogix500 7.10.00 file save error
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Anyone seen this before?
It occurs when trying to save a file while online, with or without uploading.
I have two instances of RSLogix500 opened online to two different processors, and both instances generate the same error message...
I tried changing the save path to my local drive and still no joy.
I will try to export the databases I have been working on so I don't lose three hours of work and then shut down and restart RSLogix500 to see if that helps. . .
Edit: exported to csv, shutdown both instances of RSLogix, restarted them, opened the file imported the csv, went online (forced to upload) and now it saves just fine...
In RSLogix500, is there a way to make B3:1/1 to show as B3:0/16? In the below drawing with keyboard letters, --II-- is a rung with a normally...
2,089
Hey all, I have: 30 Float Data File each containing 256 elements. I want to clear the values of all the 30 Data Files, how can I accomplish this...
2,554
Can someone tell me if there is a difference between the B3 file and the B9 file? I was troubleshooting a program that was using a B9 bit and not...
1,879
Greetings to EveryOne: Anyone here has the RSlogix500 software. Attached file is the SLC program that need to be convert to pdf file. Thank you...
2,684
Hi Guys, I have a SLC 503 CPU that I go online with fairly often and never have a problem. Today when trying I got a "No Matching File Found"...
5,771
