RSlogix500 B3 file bit number
unsaint33
Sep 2019
MInnesota
118
In RSLogix500, is there a way to make B3:1/1 to show as B3:0/16? In the below drawing with keyboard letters, --II-- is a rung with a normally open contact.
From this
B3:1
--II--
to this
B3
--II--
Sure, change the binary bit display mode to /bit instead of word/bit.
Right click in the ladder, properties, and go to the address display tab.
You will not see B3:0/16 but you can see (using Dravik's configuration) B3/16 (word 0 only has 16 bits 0-15 B3:0/16 is not a valid address)
which is the same a B3:1/0
B3:1/1 is B3/17
I am pretty sure that B3:1/1 is actually B3:0/17, and it will display as B3/17, but assuming that [B3:0/16] is a typo on the OP's part, Dravik's answer still stands:
Is there a way to do the same for timers?
Not that I'm aware of.
Timer data structure is actually three words.
One for the .EN (enabled bit) .TT (timing bit) .DN ( done bit)
T4:0.EN T4:0.TT T4:0.DN
One for the Preset .PRE
T4:0.PRE
One for the Accumulated Value .ACC
T4:0.ACC
Can someone tell me if there is a difference between the B3 file and the B9 file? I was troubleshooting a program that was using a B9 bit and not...
1,871
Hey all, I have: 30 Float Data File each containing 256 elements. I want to clear the values of all the 30 Data Files, how can I accomplish this...
2,543
Greetings to EveryOne: Anyone here has the RSlogix500 software. Attached file is the SLC program that need to be convert to pdf file. Thank you...
2,681
Hi Guys, I have a SLC 503 CPU that I go online with fairly often and never have a problem. Today when trying I got a "No Matching File Found"...
5,750
I am running RsLogix500 v7.10 to connect to several SLC 5/04's, 1747-L543, Ser C, F/W 10. My question is, until last weekend, We had a feature...
3,101
