RsLogix5000 V16 Add-Ons
Contr_Conn said:
Switching gear a little:
Did you try these new features?
- Unicast for Ethernet I/O
- Alarm instructions
- 64-bit Long Integers (search for LINT in KB)
- Firmware Supervisor (scary) - no manual yet, search KB
-Unicast?
Care to expand?
I actually made mistake:
Unicast is for Ethernet Produced/Consumed tags only,
I/O unicast is not implemented in ver 16
Before ver 16 prod/cons tags used multicast communications over the ethernet to provide have more than one consumer.
Multicast created problems for some IT networks and did not propogate through the routers
Unicast will allow direct producer/consumer communications
I have used 1 Addon block in the Rslogix V16. the block contains two Local timers whose .PRE values were initialised in the Addon logic only.
This block was tested in rslogic Beta V16, and it was working satisfactory. But when same block was used in Rslogix Released V16, The timers were not taking the default values.
if i initialise the values by going in the main program instruction, then it started working.
Have anyone faced this problem, if yes then what would be the solution?
Hi Guys, Can anyone please tell me how to remove an Add-On Instruction from RSLogix5000 V16? I'm cracking up here!!!!
18
49,780
Hi Guys, Has anyone experienced errors while attempting to delete an Add on instruction in RSLogix 5000 V16.00? I have removed all logic...
63
The help file for RSLogix 5000 v16 mentions several instructions that cannot be used within a custom Add-On:JSR Jump to Subroutine...
6,812
Hi, It's my first time using RsLogix5000 V16. I'm wondering if it's possible to have a rsview studio application commnunicating with Add-On...
3,712
Hi, Anybody have link to download RSlogix5000V16 as I can not find it anywhere Regards Sandeep
1,417
