RSLWorx for Devicenet Questions
robkaos
Sep 2013
PA
Hello, sorry if I don't phrase the following correctly; rather new to this.
1. I've got 10 Allen Bradley 1747-SDN Device Modules that will be used for Elevators.
2. I actually only need the software - RSWorx Devicenet; if I purchase the software, can I install the software to be used on all of the devices or do I need licensing for all 10?
Again, very new at this, so any help is appreciated.
Welcome to the Forum!
Any Rockwell Automation software purchased license is "activated" with regard to the PC the software will be installed onto.
One or one thousand 1747-SDNs will require one RSNetWorx for DeviceNet license if only one PC will be used to connect to the scanner attached networks.
So if I wanted to use the software on more than one computer, I'd have to purchase it again then? Damn. Thanks
You can use the software on only ONE computer at a TIME. You could have the software installed on multiple computers and use an activation dongle to activate the software on a particular computer.
You could purchase a "dongle" type activation which will locate the .lic file on USB media; you could install the software on as many machines as you wish, however, you will be able to use only the one which has attached the "dongle" USB device containing the license file.
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
116
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
159
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
141
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
215
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
115
