RSNetworxII For Controlnet Crash
asterof
May 2007
Califonia
554
Actual it only crashes when I try to configure
a contrologix chassis in the graphic layout
All other are ok
XPPRO
anyone have a similar problem
While this may be necessary for a PLC-5 system, if you have a CLX system why are you doing this? Once you go online it automatically fills in the module identity. There really isn't any need to do this for the CLX.
But to answer your question, no I don't have this problem. But then again we may not be using the same versions.
OG
OG
because you may need to create a file off line or add a module
that is a custom
I do not agree with that statement
There are times when adding a module in
RSLOGIX does not get it write
there does not need to be a link between them
and many times it is better not to link them
that does not solve the issue anyway
asterof
You got correct answer above:
To add any controlnet module to ControlLogix project you must use RSlogix5000.
You use RSnetworks for scheduling only
It sounds likely to me that attempting to insert a ControlNet connection "backwards" using RSNetworx instead of RSLogix 5000 might be the cause of the software crash you describe.
It will help if you post the versions of RSLogix 5000 and RSNetworx for ControlNet you are using, and describe in detail the steps you are taking and the error messages or software behavior you are observing.
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
209
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,319
I'm having an issue trying to backup a ControlNet network. Within RSLogix5000, when I click on Module Properties of the 1756-CNB (Rev 5.001), the...
870
An issue occurred at an organization here in whereby the ControlNet card developed a fault. Card Details: Catalog/Series; 1756-CN2RXT B Part No...
447
Hi, We have ControlLogix installed at my plant with Flex IOs communicating with controller through ControlNet module. Yesterday, while controller...
496
