RSView32 & Corrupted User Profile
Maximuse
Apr 2013
Ontario
51
I have a customer that had a power outage which resulted in the PC having a corrupted user profile. He resolved that issue by repairing the operating system but now when he tries to open his Scada file in RSView32 he gets the following error messages:
Failed to update source DSN
ODBC connect to HOTESTSR failed
After some searching on this forum I found Gil's advice:
Give the info below a try just in case cache files are in conflict with your project.
A repair I do if any issue crops up, is to shut down the project, then in Windows Explorer, go into the project folder, open the cache folder, and blow away all files in that cache folder, they will be rebuilt on the next start up.
The next thing I do is go to the projects Tag folder, and look for one file with "the project name".cac
I THEN BLOW THAT ONE ONLY AWAY, leaving all the other files in that folder, this .cac file also will be rebuilt on project start up.
Then shut down computer and reboot and run your project.
I cant promise this will fix your problem, but it wont harm it either.
If the above dont help
Go to start/ program files/ Rockwell software/RSView 32/Tools/Database Import Export Wizard and Export the database, then Re Import it, this will test the tag syntax etc to make sure errors don't exist.
This great advice unfortunately didn't solve the problem.
Any other suggestions? Many thanks in advance.
I should add I am by no means an RSView32 expert so hopefully my description of the issue makes sense. I've only ever used it for visualization, not for Scada.
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,915
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
602
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,440
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,307
