RSView32 dbf to an excel report
Gil47: I tried to use pivot tables with the dBase IV Wide format and I always get an error when I try to get the data. Is it possible that the pivot tables work only with Narrow format?
Short answer: Possibly Yes
Long answer: All my Datalog model use narrow format and using the pivot table changes it to look more like the wide format, so if you already have the wide format you are now looking for a linking of the <20070912AT.dbf> to the <20070912AF.dbf> , which is in that chapter 16 with the pivot table section.
I assumed it was all part of pivot tables and after reading Lancies post 13 and 14, I went and read the section in the chapter 16 and now wonder if I may have clouded the issue.
Chapter 16 is going to be more use to you than I will be.
Best of luck
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,526
Greetings all,I have an existing RSVIEW32 project that is running on a computer which is connected to our "production network". The production...
3,371
I have to produce charts for a month's worth of these dbf files. There is one file for each 6 hour cycle. Anyone have any ideas? I could...
1,955
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
410
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,932
