RSView32 loses primary configuration driver setting
brian7619
Nov 2011
Ogdensburg
Hello,
I am currently having a problem with RSView32 v6.4 on windows xp. When the pc is shutdown unexpectedly, I lose my setting for primary configuration driver and it says "none loaded". I am running rslinx pro v2.41 and running it as an application. I have read on rockwell help links to try running as a service. When i change the setup utility for rslinx to run as a service i lose my communication for some reason. I am not sure what the difference in running as a service and running linx as an application is. Any help or ideas would be appreciated.
Thanks,
Brian
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
389
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,922
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,449
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,313
