RSView32 OEM Application Security
Sydney
Nov 2011
Central Coast of California
61
Hi all, is there a way for an OEM to lock/prevent a RSView32 application form editing. I have a customer that says he can't modify his application and says the OEM has him lock out. I'm not that familiar with RSView32 and couldn't find anything in the manual about application security.
There were tools that came with RSView32 that could lock down the application as well as attempt to secure the Windows operating system it is running on. You could disable access to the start menu/task bar and windows key with one or more of those utilities.
As for the application itself, I think that you could block access to the manager menu (ctrl + p) with a setting in RSView32 or one of those utilities.
Also, I think that RSView32 was sold as a Runtime only as well as a "works" (development) license. My memories are fuzzy, but we do have a couple of customers using it, so I occasionally have to get in and poke around.
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
376
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,913
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
599
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,437
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,307
