RsView32 PrintDisplay to PDF to non default printer
robbo
Nov 2005
Australia
85
Hey fella's,
wonder if someone can help me out here?
I have been doing some 5pm reports to the default network printer for a few months - I come in next day, and all the screen dumps are waiting for me in the printer which is good.
There is a new request now. Need to either:
1..print a screen dump to a different network printer once a day
or
2..convert a screendump to pdf once a day (probably event driven) and save it on the network somewhere.
Just looking for commands to change the default printer etc for a minute, or commands to send to a different printer etc
Tah.
Robbo, It is probable that your "screen dumps" are being controlled by a Visual Basic file running inside the RSView32 program (possibly controlled by an Event in the RSView32 Works "Logic and Control, Events" menu). If that is the case, you would have to edit that VB file to change the default printer address.
On the other hand, if the screen dumps are simple screen prints of the displayed screens, then you can set the default printer from the Windows Start menu: "Start, Printers and Faxes", then right-click on the installed printer that you want to be the Default, then select "Set as Default Printer".
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
601
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,439
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,307
