RSView32 to SLC5/04 handshake
sparky64
May 2003
Newcastle upon Tyne
127
I'm collecting a 28 character string of data, using RSView32 ODBC data logging in to an Access database.
The string is made up of 2 seperate pieces of data, 14 characters from the product ID, which are the first characters transfered into the Integer file. The machine then goes through its cycle and then transfers 14 characters of process data in to the Integer file. When all of the data is in the correct words in the Integer file, i set a bit, to flag RSView to take a snapshot of the Integer file.
Intermittently the process data part of the Integer file, is not being recorded in to the access database?
Is it possible for RSView to monitor the data is has snapshot, and then write a handshake bit back to the plc if it got the data or not. Would I have to create an expression to do this using the "SET" command?
Does anyone have any expression examples.
Thanks for any replies
Sparky
Hey All, I’ve got a problem for anyone experienced with SLC5/04s running on DH+ controlled by a windows 98 desktop running Wintelligent View. So...
2,022
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
380
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,917
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
605
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,444
