RSView32 with OpenOffice Ca;c
nikhilec2007
Dec 2014
Gujarat
36
Has anyone ever tried reading data from Open Office Calc (Similar to Excel) using RSView32 or FTView SE (VBA).
If yes, please guide me...
Open office has an option to save in Excel format. I haven't tried to do what you're doing but if the document format is the issue then you could try that route to see if it helps.
I am not quite sure about VBA, but upto my knowledge, we need to connect to excel object to read data and excel needs to be installed in same pc. Is thare any way to read excel file without installing excel in pc.
A long time ago, I looked into this with DDE, but since OpenOffice used (at that time) a form of Basic very different than VBA, I had to research the syntax and do things differently. I ended up finding that some other person had hit a brick wall with the communications, and I was just experimenting so I stopped.
That was in about 2006, so things may have evolved since then.
EDIT: I have no time to read this thread, but see where it leads:
http://www.oooforum.org/forum/viewtopic.phtml?t=39364
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
376
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,913
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
599
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,437
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,307
