RSview32
What my colleagues are trying to get through to you is that you are using an obsolete Microsoft Windows OS and an obsolete Rockwell Software visualization software package.
The "32" in the product name is a hint that RSView32 is a 32-bit program.
Despite the "No known issues" gray dot in the the Rockwell compatibility table, I know that RSView32 and its 32-bit Watcom database engine are not designed to work on 64-bit operating systems.
Even if you have Windows 8.1 Professional 32-bit, that OS is one of the least stable and popular ever made.
I would recommend Windows XP SP3 32-bit as the most stable operating system if you really do have to install RSView32.
I vehemently disagree. That title surely belongs to Windows Vista.
Everything else Ken said, I wholeheartedly endorse :nodi:
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
375
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,913
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
599
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,435
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,306
