RSView32
hjdjacket03
Guest
H
I have 2 trending screens and one was copied from the other but know one of them is showing the lines for the trend and not the legend and the other is showing the legend not the lines. the pin config. for both is the same just w/ the different tag information to show in the trend. Any help would be helpful. Post here or email me at [email protected]
I am assuming this is the built-in trend function and not the RSTrendX component.
One thing I always do is use a different control tag for each trend. Otherwise, configuring one makes changes on the other.
On the first screen of the trend configuration change the control tag to a new tag. Type in a new name and it will create the tag for you.
Actually it will be a folder with a whole series of tags under it.
OG
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
385
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,921
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,448
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,313
