RTD conditioning in rslogix5000
suraj2k
Nov 2012
Calgary
very simple question:
I have an RTD input card (1756-IR6I) on a ControlLogix5000 chassis. I have several temperature sensors connected, the input range = 1-487 ohms.
what kind of analog conditioning code do I use, to translate these incoming ohms (raw data) to temperature values that I can use in my program?
I'm coding in Ladder Logic.
I just don't know what the raw data looks like, or what my analog conditioning should look like.
Any assistance would be appreciated.
Thanks!
thats great. So as long as I configure the Configuration window correctly with the correct Engineering (High and Low) values, I can refer to the Channel.Data in my program, and that Data will be in whatever Temperature units I've chosen. Right?
Thanks!
Thanks!
Right. Post the program ( zip it first) if it does not work out for you.
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,211
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,655
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,109
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,071
Hello! I have RTD sensor with 4 wire and shield ( 2 red wire + 2 white wire + Shield) and I want to connect to 1734-IR2 module. But in the manual...
1,458
