adamp Member OP A Join Date Mar 2013 Location newfoundland Posts 12 Mar 30, 2013 #16 Not sure if this will work
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Mar 30, 2013 #17 The first 4 channels are configured ok. The open circuit configuration is set at "upscale". Which means if you have an open circuit the value will be 32676 which is what you have, except for channel 0 with -32676 look for a short. I'm back to a wiring problem. Last edited: Mar 30, 2013
adamp Member OP A Join Date Mar 2013 Location newfoundland Posts 12 Mar 30, 2013 #18 Switched two of the wires and it works perfect. My bad I had the wrong wire wired to sense. Thanks alot!
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Mar 30, 2013 #19 Thanks for coming back with your solution.
