RTD's for SLC500 example
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day. New to slc500 programming, have never programmed it for analog addresses (inputs). The inputs turn-on and off industrial tank heaters. I have tried, unsuccessfully, all day to get it to work! Would anyone have any advice or even a sample rung or two would be greatly appreciated.
is there any way that you can post your RSS program file? ...
(no offense intended, but it seems like we've asked this before) ...
we'd love to help you with the questions that you're asking - but we could literally write a book on how to handle analog signals - and we don't even know at this point what types of modules you're using ... different hardware requires different answers ...
if you can NOT post the program just say so – and we'll try to come up with another line of attack ... I assure you it will be a LOT more difficult and time-consuming at your end – and at ours – but we WILL try to help ...
on the other hand, if you're allowed to ZIP the RSS file and post it, we can probably help you with a minimum of time and effort ...
the more we know – the more we can help ...
PS Edit ... if you can post the program, please also tell us EXACTLY what type of RTDs you're using ... in most cases, you can't set up the module configuration without knowing that information ...
Ceiling can you clarify one thing In your above post? You mentioned you want to turn on Outputs with an Input card? with the statement " The inputs turn-on and off industrial tank heaters. "o_O
Ron is right we need to know a lot more of whats involved before we can answer that.
I'm pretty sure that he means, through the logic, these analog inputs (RTD = Temperature Input) will control the outputs which turn on/off the tank heaters.
LOL didn't think of it that his way of asking tripped me up I guess no offense we will gladly guide you on, but we do need to know more details lol
Tharon is correct. The logic will turn the heaters on and off, using inputs from RTD's. I'm trying to figure out how to upload my program here. Thanks for your patience.
Good day. I asked a question here several days ago pertaining to the same issue and I was asked to upload my program. The program is 10 pages...
4,748
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,209
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,652
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,096
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,067
