S5-115U Hidden programmed Blocks
EEPROM doesn't have anything extra than what is shown in PLC directory?
Correct
Then where are these PB16 to PBxxxx located?
Good question.
My best guess is that they have only existed in RAM, and that a power/battery outage has deleted them.
Kalle
Hello Kalle,
Well if that is the case that they perhaps have been deleted, then Why doesn't CPU give a compilation error as the BLOCK CALL still exists in OB1?
Machine ran absolutely fine so far until now that my interface PC failed.
Yes I will make OUPUT PLC MEMORY FILE, probably tomorrow...
I got the full Hard Copy of all the FBs and PBs in the directory....And I could not find any reference of these Missing PBs anywhere else, But in the OB1 where they are called.....
As I said earlier; I mean that this type of CPU runs OK even if PBs are missing. But if a non existing DB (-area) is accessed by the user program, it will stop.
Kalle
Could it be that your type of machine is a part of a bigger system and that irrelevant program parts are deleted / omitted by the OEM?
Dear Sir,
It's a simple independent batching plant. I strongly feel these PBs have interface Program which deals in Recipe Orders handling, Giving commands to PLC for Dry Mixing Time, Wet Mixing Time, Actual Weight = Nominal Weight, Scale Empty etc. etc.
Because I didn't find this logic in the given PBs/FBs....
Hello Dear, I am using a PLC SIMATIC S5 115U CPU 943B my problem that there is no output on CPU (943 B) ⚫️RUN STOP 🔘RUN 🔘STOP 🔘QVZ 🔘ZYK...
2,462
I did this once before but it was about 30 years ago I just tried it on a plc this morning and,when i fitted the eeprom and downloaded the...
2,158
Hello, I have a question that is bugging me, hope someone can shed some light on this I have a STORK filler that i have just added a new CIP...
1,620
Hello, The thing is that I don't have to much experience with siemens and I have a problem, I think the problem is the CPU, because all the red...
4,184
I have a Simatic S5-115U CPU 945 PLC and an Interbus card IBS S5 DCB/I-T This PLC it's from a master machine, which was a part of a complex...
25
9,614
