S5 135u problem
mohamedzobaa
May 2008
Cairo-Egypt
75
I have two cpu with coordinator and cann't make online with them
although they have a problem and i make overall reset and they are run mode now but still gives me plc timeout if i try to make online through any of cpus or coordinator .......i need help
Do you have a PG or an ordinary PC? If you have an ordinary PC the trouble can be that you need a tty converter.. Some of the old comm-modules needs this.. Im not a step 5 guru so I hope someone else can give you a better answer..
mohamedzoba,
Not sure I understand everything, but if you post the part numbers of the CPU's and more information on how they are communicating with each other. Plus your PC/PG setup and cable I will see what I can do.
Larry
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,267
Dear experts, I need your advice. I am working on project where we use S5 135U system. Our configuration: CPU: 6ES5 928-3UA12...
1,778
hi... i'm newbiew about this hmi and plcs... And... there is this old application running on ancient "windows 3.1". i think it's communicating...
1,358
Hi, I tried to backup program from PLC but all I got was couple of DB's and DX's. I used STEP5 and S5 for Windows, both showed the same blocks...
1,965
problem in a communication that lost bet. S5 135U (ALARM S3964RDDE SERVER) & In Touch Hi all experts and members ...
2,128
