S7-1200 Modbus Communication RS845
juanmdx
May 2007
SLP
281
Hello,
I'm trying to communicate an S7-1200 to another PLC via Modbus using RS485.
The S7-1200 will be the slave and I want to send some data to the other PLC (don't know which one, they'll send me the address and communication settings), and they want to write some data on the PLC.
The thing is that I don't know how to read and write data, I used the modbus blocks to "start" or stablish the communication (haven't tested it yet), but I don't know how read or write parameters; I've searched on Siemens forums for a while and still can't figure it out.
Can someone please help me.
If you need more info I can give it, but bottom line, I wan't to know how to read and send parameters via Modbus using TIA portal and my PLC being the slave.
Thanks and best regards.
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
409
Hi ! Everybody ! Please..help me about communication between S7 1200 and inverter or any varispeed inverter had MODBUS support by module CM1241...
20
11,201
Hi, I have a S7-1200 and Beijer HMI. These are communicated with ethernet cable. I want to do that PLC communicate with another device via RS485...
2,162
Is any one experience with s71200 any module support modbus TCP Communication?
1,775
Hi! I have a S7-1200 1214C with RS232 Communication Module (CM1241) as Modbus Master I found an example of work with MODBUS in here...
4,427
