s7 1200 modbus ethernet ifix 6.1
balash
Dec 2012
Koprivnica, HR
418
I have two PLC s7 1200 connected to remote site with 192.168.45.x subnet
on that site i have ifix 6.1 with MBE driver with modbus tcp to both plc's. On local site, 192.168.5.x subnet, i have ifix 6.1 with mbe. now the problem that bugs me is that i can see plc on remote site ifix if i leave use router option blank, and if it is checked and gateway ip entered that i can see it on local ifix, but not on remote.
how can i see them on both sites?
plcs are connected to mikrotik router which is in bridge mode to main router that is connecetd to external modem and that modem is connected to local site via VPN
(y) thanks that solved the problem.
Good and also good that you confirmed that it solves probles. Then also others can find solution for same problem afterwards.
Siemens MB TCP socket function is different than on other PLCs, learned it also hard way.
Hi All, I have the foll query: The new S7-1200 CPU's have Integrated PROFINET interface The integrated PROFINET interface is used for...
2,426
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
384
Hello all. I am trying to read out the values from a Carlo Gavazzi EM340 energy analyzer via Modbus communication. The S7-1200 PLC has the CB1241...
29
3,803
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,621
