S7-200 communication with Lenze Drive Series 9300
djpalaz
Jan 2007
Montreal
57
Hello,
I was wondering if anybody knows how an S7-200 can communicate with two Lenze Drives Series 9300? Communication through modbus, profibus, etc... and not digital I/O's or analog signals.
More info
These are the Fieldbus modules, that work with the Lenze Drive would ModBus work with one of these modules.​
2102 LECOM-A/B/LI
2111 INTERBUS
2112 INTERBUS loop
2131 PROFIBUS-DP and 2133 PROFIBUS-DP
2174 CAN addressing module
2175 DeviceNet / CANopen
As per our last machine we built, our client sent us profibus modules at the time we just use analog signals to send a reference speed. However we would like to communicate with the drive this time using the PLC. As far as I know the S7-300 can be master on profibus network however it has been already been specified that we are to use an S7-200. The S7-200 can only be a slave on profibus network. Please correct me if I'm wrong.
Hello djpalaz;
You are right, the S7-200 EM277 can only be a slave on Profibus-DP, and I can't find any data on drivers for the other protocols you mention.
Since you are stuck with the S7-200 (very good PLC by the way, but limited in memory and performance) you could look at a gateway, such as this one:
http://www.duranmatic.nl/nieuw/Groep1/brochures/Renu/gatewayfamily.pdf
It supports S7-200 serial to DeviceNet, could be of some use.
Hope this helps,
Daniel Chartier
TP177B Profibus Master
Hey All,
Does anyone know how to configure a TP177B PN/DP to be a Master on Profibus network?
Hi I want to establish a connection between Lenze 8200 and s7-200 cpu 226 Using RS485 or in other words Modbus Please Help
2,282
Please help me how to connect Lenze vector 8200 + Lecom communication modul+ computer to upload parameter from Lenze inverter 8200? I did try to...
7,969
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,936
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
226
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
392
