S7-200 online with GPRS
ason
Oct 2005
Home
317
Hey, i wonder what i need if i wanna connect from work to a PLC s7-224
is there any gsm module that i can use GPRS or regulare modem?
You could take a TC35 for simple GSM (SMS + Data connection).
You need additional a PC/PPI cable 6ES7 901-3CB30-0XA0 and small gender changer (<1 EUR).
For GPRS there is the MC45 but there is no built in TCP, refer also tip19 from microset (www.microset.de).
Otherwise take a modem with built in TCP and controlled fully by
AT commands (use then freeport from S7-200).
thanks for the tip,
going to take a closer look at them.
i wanna use it in this way,
i need a product that i conf. to the 224 so it works before we ship the machine and then i disconnect the modem and hopefully it will work without the modem.
and if they need some changes i ship the modem or what else to costumer and they connect it to the s7-224 plc and i dailin or something,
Any modem could do the job. However due the modem synchronisation problems on (inter)national connections the EM241 was created for. You should use them if applicable, since is optimized to communicate with PPI.
Em241(about <400EUR) is for fixed line only. If GSM is only available take a TC35(about 140-200EUR).
For TC35 and regular modems the NEW PC/PPI cable (6ES7 901-3CB30-0XA0) is required and a simple gender changer (1 EUR).
While connecting the EM241 the power supply must be disconnected. For TC35 or commercial this isn`t required, but while connecting them could occur some short communication error.
P.S:
You should program the modem settings before delivering.
The most importing setting is for take off after X time rings.
ATS0=1 means take off after 1st ring. Save the configuartzion then. Refer the modem manual on AT commands.
The Em241 don`t need presets.
I wonder, if i have a program that is conf. for a MC35 and working,
and i calling in to the PLC and going to download a new program, what will happend?
do i need to restart the PLC and dont i lost the connection then?
do i need to have a human person there to restart and put it in run mode?
The connection wouldn`t be lost. There is no local human required.
Microwin could set the CPU remote in Run/Stop and even power reset.
Don`t forget to set the register S0=1 as i mentioned before (AS0=1 + ENTER; store then your profile AT&W0 + ENTER)
The Microwin Modem assistant can help you on that TC35(MC35), the init string is already there.
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
242
i am a beginner learning Plc and Hmi programing.I am practicing on siemens s7-200 micro win and canal plc simulator to test program as i do not...
3,905
Here's a weird one... There's a Micrologix 1200 in the plant that uses NET-ENI to conect with the rest of the plant network. Lately, I notices...
2,407
I seem to be having some trouble getting online to a new S7-1200 PLC. It has the new version 3 firmware. I have upgraded Step7 to SP2 Update 4, as...
4,722
hi friends, is it possible to edit the programme in online for s71200 plc.???? whether any other siemens PLC support online editing. if possible...
2,433
