S7-300 First Ethernet Connection
Not able to Browse MAC addresses
Hello,
I have two adapters on my PC, but I have chosen TCP/IP with the correct adapter on "Set PG/PC Interface".
Even so, I am not able to browse MAC addresses on "Edit Ethernet Node". I have tried disabling Fast search. And I have tried connecting the adapter to both a ProfiNet IO Device and to the Siemens PLC, neither of them gets seen.
Also, I am able to ping the PLC from my PC.
Please help.
Thanks,
Srikant
Try to remove everything else but the S7 CPU and the PC. Connect with a direct cable. I have seen that some other device that was not configured could mess up the scan for MAC addresses.
Jesper, I have disconnected and also disabled other network cards. I had only the PLC, directly connected to the PC, but it still didn't help. :(
I am able to download to the PLC from the HW Config window.
I was earlier changing device name for IO Devices from the Edit Ethernet Node window -- I would connect the IO Device to the PC, and after browsing, I would change the IP and name as needed. Now I'm not able to do that!
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,013
This is my first time using these E300 overloads in an application. I used "Discover Modules" to add them so that they would be added just as...
5,500
Hello! I need to know if its possible to transfer data between two PLCs that are on the same ethernet network but NOT contained within the same...
3,418
We have S7 CPU 319 which connected with Hitachi PLC with CP-343 Lean Module. It was working fine . But some reason Hitachi PLC was resetted ...
4,297
Hi folks, I'm having trouble connecting to a Siemens Simatic S7-300 CPU 315-2PN/DP via ethernet from a PC using Hyperterminal, I have the correct...
28
21,935
