S7-315 2DP connected to an EM 277
hagos
Oct 2004
Africa
244
Dear folks,
I'm still in the data assignment for about 24 S7-200 slaves (connected using 25 EM277). connected to a S7-215 2DP master.
My question is I want to read/write 32 bytes for each slave, can I go beyond the I/0 126 ? i.e can I use I/O 500 for one slave then use SFC 14 & SFC 15 to transfer the data of each slave to a dedicated DB?
Best regards
Hagos
Yes, SFC14 and SFC15 are the blocks to use when you have i/o that is not inside the "proces image" of the CPU.
Check also the total addressable peripheral i/o range. The current generation S7-315 can address up to 2048 input bytes, and 2048 output bytes.
hi there its my firest time working with profibus and i have already install gsd and networked profibus in step7 hw config and inserted base...
2,518
Hi all, I need to connect a S5 095-8MB02 cpu (Sinec L2) to a S7 315-2DP (Profibus DP) for transfer of analog signals between the two. Does any1...
2,154
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
71
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
790
