Maybe this is obvious to someone more experienced with DP/DP couplers than I am.
We have setup a system with my PLC connected to a supervisory PLC via a DP/DP coupler.
Notice that there are OLM copper-to-fiber converters in between the two Profibus networks.
What puzzles me is that the very first input bit in both directions is always on. It cannot be controlled by the corresponding output bit in either of the PLC's.
For example, my inputs start at I40.0 and this bit is always on.
Is this normal ?
Is it kind of a status display that the connection is OK ?
Everything else works as expected.
One thing is that I have set the DP/DP Coupler to be "fail-safe", i.e. Inputs goes off if the connection is lost.
Is this normal ?
