s7 going online via profibus
andybeesley
Aug 2006
liverpool
I've recently aquired a job where several s7 plcs are connected via profibus. I can get online ok individually thru the mpi but can i access all of them via one plc using the profibus connection?
I'm presumimg you meant going on-line with more than one PLC from a single PC.
The answer is yes definately via ethernet, profibus I believe so, but not definately sure.
EDIT:
With ethernet it is also possible for more than one PC to connect to a single PLC.
Profibus Works
I regularly use two S7-400 PLC's and two PC's all connected via Profibus using CP 5613 or CP5613 A2 cards in the PC's.
The PC's each run Step7 and Citect SCADA and any device can
communicate with all the others.
Yes, you can. For example, I have 1 CPU313 as master and 3 ET200S CPU as slaves in one project. I can watch all of them in online through MPI/DP adapter connected to any point of DP network.
... and with S7-400s definitely (though I'm not sure about which S7-300s support it) you can use the PLC as a router e.g. connect to the PLC via Ethernet and route out over Profibus to the individual devices.
Ken
Hi all, i have a plc rack with control logix 1756-L61 (rev 12) and in the rack is the plc, controlnet card 1756-cnb/d, and the 1756-enet card...
1,549
Hi guys, I am new in siemens software and trying to go online with a plc S7 300 via router, this is what i have been doing, first i connect my...
1,788
Hi, Im pretty much inexperienced with Control logix platform. We have a new machine that has controls done with it. Problem is I cannot...
1,635
hi, I have been looking for the last 4 hours without any solution why I'm not able to go online on SLC5/04 via serial cable. I have a plc...
4,771
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
419
