Hi dear programmers,
Im a newbie in plc programming, i start using s7-graph to program a palletizer i wrote a typical program but im facing a little problem :
I wanted to use the OFF_SQ input from the called block wich is generated by s7-graph compiler, i used it to stop the sequence once the emergency button or the stop PB are pushed but it seems that once the OFF_SQ input is active the whole seuences are desactivated and if i wanna go back to the normal executing i have to INITIALIZE the graph with the INIT input.
I wish i could go back to the step wich at it the EM or STOP PB were pushed so the sequences could continues normally.
If its not possible pls advice the best way to do this and what is the better method of writing sequential programs if s7-graph not highly recommanded.
Best regards,
Abderahim
Best regards,
Abderahim
