Mmmm! This isn't as easy as it looks!
Actually, I don't think this is going to be the solution for my Merker problem, there are just too many bits and pieces to be moved and too many things to go wrong.
However, it did look like the solution for another problem I had. I've got a DB which holds the table of delay times before a Module can be reused, depending on what Voltage (i.e. how much energy) it was used with the previous time. There are two factors to be considered here:
1) The cooling time of the Pulse forming coils, when the module is triggered into the load
2) The cooling time of the Dump resistors, if the module's energy has to be dumped in a fault condition (or on a trial run).
It turns out that the cooling curves I calculated are about right for the coil, but are off by a factor of two for the Resistors. The easy way to solve the problem is to copy the DB and modify the delay values. Here we run into that old favourite, actual vs. initial values. So I created the new DB, then followed your steps to modify the initial and actual values in the source file and then recompile it.
And that's where the problems start. I get 5 compiler errors, two in line 1, one saying there's a Type conflict with the first word in the DB Name - "Dump Module Delay " and the second saying that the Symbol "Dump" does not exist in the Symbol Table, etc.
OK that seems clear enough, evidently the Editor can't
cope with spaces in the DB name, although Step7 itself has no problem there. Recopy the DB this time using "underlines" instead of spaces and try again. Well it got a bit further but hit trouble in the first line of the DB data which is the length declaration for the look-up table. It gives (amongst other errors) a syntax error for *"W#16#19;"*. OK, I thought, maybe it doesn't like the semi_colon; so I removed them in Editor.
Try again same story, so delete the quotes. Now I'm left with the last set of error messages - "There may be an incomplete declaration, or the sequence is wrong" (loosely translated from the German).
So I went back to your Post again and read it carefully, in particular:
Save the file with "Save As", accept the format "Tab delimited .txt". Close the file and choose "No" when prompted to save with special formatting.
Maybe there's a difference between the English and German versions of Excel, but if I answer "Nein" to this message:
Excel just abandons the save.
By the way, this 550 pixel restriction on width is a real pain, I assume it's so that the format doesn't run off the screen, but with things like these error messages, it can be difficult to get them to fit and still keep them readable. That pic is 548 pixels wide!
The same fault comes for every data line in the DB. It looks as though the formatting is somehow getting screwed up - have you any idea how?
