S7 PLCSIM: What's the correct way to modify values?
Mas01
Oct 2020
Leicester, England
1,109
Daft question coming up...When I want to modify a value, what's the best/correct way to do this?
At the moment, I am entering the value (e.g. "5500"), then pressing return.
However, when I do that, it changes the value in the cell directly below it, typically changing it to zero.
Is there a way to modify values, without changing any other values? Thanks
I don't know that particular HMI but a few things come to mind, it may be possible to turn off the automatic tab on the input fields some HMI's have this i.e. on the return key it selects the next field, although I cannot understand why on a return the next field is going to 0, perhaps a double return or the edit field is automatically zeroed seems weird.
Oh.. sucenly realised you are using the simulator, agree with the vat table on S7.
It doesn't do that for me. I type number, hit enter, that one changes and nothing else.
You could try the "Consistent Modify" option (turn it on in the SimTable properties) to change whichever field is checked all at bummer. It uses a button to trigger them all at once, which may help with whatever the real issue you're seeing is.
I'm a little bit intruiged/scared by "PLC_1[Off]" in the pic, mine always says the PLC type (assuming yours is 1200, like usual) in the brackets. Might be an indication that something weird is going on?
I dunno why it says PLC_1[off] like that. There is another window in the background with S7_1200, but I have no idea what that one does, or why it's there (pic 2).
Once again, I am fishing around trying to figure out what's going on through trial and error...plus help from you good people.
p.s. I don't know what a VAT table is.
p.p.s. Not sure how the PLCsim can be RUN and OFF simultaneously (pic 1)Screenshot 2024-02-28 101127 run and off - how.png
edit: Just watching a video on vat tables now (y)
They're called Watch tables in Portal. Don't use forces. The feature technically exists, but it isn't The German Way, and thus it's only half implemented and you'll get into trouble.
The nice thing with watch tables is that you can change tags in DBs as well (and obviously use them with regular PLCs, not just sim), whereas PLCSIM can only do I/Q/M.
The Sequences in PLCSIM are pretty cool, to help automate your testing.
UPDATE: If I enter the value, then just click in a different cell (see post#1) then the new value is updated without any other values changing.
That seems to be a workaround for me, thanks.
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
572
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
384
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
598
Hi, My PLC hardware has been delivered to customer site - many thanks for the invaluable help on this forum! I was looking into see if it's...
2,577
I'm trying to download a project for Siemens S7-1517F safety PLC to S7-PLCSIM Advanced 3.0 simulator and I'm getting incompatible firmware issue...
1,622
